Visual indicator on the label
Taking advantage of the interface being rewritten, I would like to request a permanent indication in the tab of each system showing if it is active or deactivated.
Not a bad idea, yea.
The tab UI isn't currently being changed (all operator rollouts are being re-written but the editor window will remain the same)....however, at some point in the future I would like to re-address the tabs because they can get quite messy with a lot of flows. Maybe nested tabs, or some better way of arranging them...I'm not sure...but also having an enabled/disabled indicator would be good.
