TyCache render default instances always need to switch to meshes (Arnold)
Just voting to get the TyCache default under Render be set to 'Meshes'.   It has to be switched each time for new TyCaches when using Arnold for whatever reason.
The render default is 'instances' because that's the most common use case Smile
