11-08-2023, 01:28 PM
Hey there,
Something unusual i dont understand, may be I am wrong
So I create plane 100x100 with width and length seg -10. that mean distance between 2 vertices is 10 units..
if I birth object plane and convert into cloth bind, I get particles which are 10 units away from each other. So if I use particle bind with enable proximity bind with an absolute distance little bigger than 10 i.e. 10.2, I should get bindings connected to each particles horizontally and vertically, but its not happening, it doesnt respect new particle bindings at all.....
But If I birth surface plane and use the previous particle binding operator, I get bindings as expected.....
this is unusual and I don't know why.....even particle bind when used with cloth bind don't respect target bind somehow....
Any ways no idea whats the problem, but I have attached the file, please look into the issue.
Thank you
aaaa.max (Size: 776 KB / Downloads: 191)
Thank you
