07-01-2024, 11:37 AM
Hello, I came accros this weird bug while using tycache and rendering on our renderfarm.
The lighting of the tyCache is different between the first frame of any machine and all the other frames that this machine will render next. When i render on local machine, I don't have any problem and the lighting matches the one of the other frames.
The problem can only be seen on some tyCache (the moss one) and not the other of the scene.
The only solution that I have at the moment is to rerender the first frame of each machine while the job is on the farm so it's not a "first" frame no more.
If you have any idea of what can cause this issue I would be glad to hear it.
Thank you
Thank you
