TyFlow suddenly started crashing my 3Ds Max
Hello! Yesterday in my office, my partner and I started having problems with the 3Ds Max that crashes when we open it. After various instalations and desinstalations, we got to the problem and it is the TyFlow but we do not know what is the problem. We tried with the latest version, with an year old version but the problem persists and we find no solution online.
Here I leave my minidump attached, to see if you could give me a hand.
We need to fix this so we can keep working, please!
Thank you!!
.dmp   3dsmax_minidump.dmp (Size: 2.44 MB / Downloads: 47)
A piece of software on your machine called "CrowdStrike Falcon" is causing the crash. Try whitelisting 3ds Max/tyFlow within CSF's settings to work around it.
(06-17-2024, 03:51 PM)tyFlow Wrote: A piece of software on your machine called "CrowdStrike Falcon" is causing the crash. Try whitelisting 3ds Max/tyFlow within CSF's settings to work around it.
Hello, I suspect I'm having the same issue, would you be able to confirm? Dump file is attached.
.dmp   3dsmax_minidump.dmp (Size: 2.53 MB / Downloads: 42)
Yes, same issue. It's CSF causing the crash.
