Get an error when trying to create a "tyValue" from the X key mini console.
You can select tyValue with the x key small console (Search all action).
And when you select it, a macro script error occurs.
Seems like a Max bug (I don't generate or control those macroscripts) - you should report it to the Autodesk devs.
Edit: actually I was wrong - I actually *do* generate those macroscripts...it's just been so many years since I implemented the function that creates them that I forgot I was doing it and thought they were auto-generated by Max.
The issue will be fixed in the next build.
Redownload the latest build and this should be fixed.
Thank you for your response. I noticed this when trying out an update related to tyValue.
I'm glad I could be of help to you.
