What's the best way to handle tycache with several child events? Create a separate tycache for each event? A single on the root doesn't seem to work.
Curious as to proper recommended approach.
thanks in advance!
Joel Eckert
Big Little Pictures
Found a solution. Seems obvious, but figured I'd mention it since it's all new to me.
I have a setup with 3 events, to cache them all at once, simply Add an Export Particles outside of all three. Tyflow will create an "Event_004 (Global Export)" by default. ...and this will cache everything perfectly!
Tyson FTW... again!
Joel Eckert
Big Little Pictures
Yep, either create a global export by putting a tyCache into an event on its own (or only containing other tyCaches)....or you can also instance a tyCache between events and they will be exported together.
