05-30-2019, 08:53 AM
tyFlow v0.16025 is out!
* added preliminary FumeFX support to Birth Fluid, Fluid Force and Fluid Properties operators
* added dropdown to gravity force spinners to set value to real-world value
* added vert/face normal option for Surface Force normals
* added ability to disable VRay Interface in tyCaches
* added visual cue in editor when retimer is enabled
* added option in Display Data operator to show currently playing animation clip of actor particles
* fixed a bug where PhysX timesteps were not properly adjusted to framerate
* tyCache rotation values are now exported as full floats instead of half floats, which were causing imprecision errors
* fixed a crash where dragging an Export Particles operator into a flow when another operator was selected would crash max
* fixed a bug where Export Particles additional geometry listbox was not working
* fixed a bug where adding certain operators to certain flows could crash max
* fixed a bug where enabling frame clamping in a tyCache could prevent it from properly updating when scrubbing forward in the timeline
* fixed a bug where choosing "File->Evaluate" in a script operator instead of pressing Ctrl+E would result in a script error
* fixed a bug where certain operators that do surface inside/outside checks would crash if the input object has no faces
* fixed an issue where changed to a PRTLoader's settings would not update a flow using it as a Birth PRT input
* fixed a bug that was allowing users to add tyCollections to an Actor operator, which was causing a crash when multiple tyActors were contained in the tyCollection
