Active shade render deletes timeline cache
Hey Tyson,
In previous releases, I could timeline cache an entire animation, go to the last frame and hit render....it would render immediately.  In the newest release, I timeline cache the animation, go to the last frame, hit render...and it deletes the cache and starts caching again before rendering.  Don't know if it's a bug, or if you changed something intentionally, or if I'm doing something wrong ???  I takes about an hour to cache, so loosing all of that by hitting render is quite frustrating....Any suggestions?
THANK YOU
Chris
The only time this happens is if something dependent on the flow has a render-only setting. For example, if you add a Turbosmooth to an object that particles are scattered on, then change the turbosmooth to enabled-in-render-only, when renders begin the object will change (get smoothed) and thus that will trigger a flow reset. So check for that type of thing in your scene.
In the tyFlow Debugging rollout you can turn on 'print sim reset info' to have reset notifications get printed to the listener when they occur. This may help you track down which object is causing the problem.
Great to know...THANK YOU very much!
