Move pivot problem since 16060
Hi Tyson,
i've just noticed a problem with Move pivot node when applied to a scaled vray proxy.
Look at the 2 screen captures. Same setup, 2 different versions/results.
Shape is a vrmesh file, scale is 1%. Same problem if scale is applied inside the shape node.
regards
Upload the file please.
replace the shape with any other vrmesh. Hopefully you should notice that the pivot is not well placed.
.max   temp.max (Size: 568 KB / Downloads: 390)
Thanks! I'll take a look when I get the chance.
Edit: should be fixed in the next build.
