Export particle mesh as one object?
Is it possible to export the particles as on object/mesh into one object? I've tried to see if I could just export them as objects then attach them together in edit mesh but it not only slows down my computer when it finally completes it messes up location of all the particles. I just would rather try to have it be a one object mesh then try to export alembic?
You can use max's Snapshot tool to convert your flow's mesh into a raw editable mesh object. Make sure your particles have a proper Mesh operator set to non-render-only.
Earlier I figured out I could export to alembic. Import it back in then just do a convert to editable poly. I'll try this other way as well! thanks!
