04-01-2020, 02:16 PM
Hi there,
I'm using Tyflow for some parametric modeling, so far so good but when I get to close in the viewport just dissapears... is there a way to avoid that to happen?
For instance all but the teapot and the base geometry is scattered, but if i get just a bit closer.. everything is gone. Of course I could just TyCache each time i need to check something but I loos the interactivity adjustments.
The scene is not strangly small and the viewport clipping is to the max. so is not that. ( that teapot is 128cm ( 1u 1cm))
max 2020
last gpu drivers.
max 2020
last gpu drivers.
