Surface area, volume test after voroni
Can someone explain why red circled fracture has a bigger surface area than pink ones? Same goes with volume.
[Image: image.png]
Are you sure that little fragment is not an attached element of a larger particle? You can confirm using a Display Data operator to see its ID and surface area.
Yes that was the case, sorry for the dumb question. Somehow I assumed that Voronoi automatically defractures every element.
On concave input geometry, that's not always the case.
You can use the Element Fracture operator to split mesh elements into individual particles.
