How to set "target" for Custom Properties?
Question
Hello, I solved my original question, so this question is edited:
I wonder, how I can work with "targets" in the custom properties operator.
In the attached scene I was trying to use the targets.
(It worked with "self" after some adjusting)
There is the option to "Set" Values as target.
I did not find something detailed in the documentation.
It would be great if someone could explain.
.max   TF_RoofTiles_Custom_prop with target_max2018.max (Size: 996 KB / Downloads: 315)
(12-22-2020, 04:26 PM)Alexx31 Wrote: Hello, I solved my original question, so this question is edited:
Although it is lengthy, you can easily understand it by referring to the video below.
https://youtu.be/hVb-NTCGuvI
