change position by animated texture map
Hey!
how to simply transform (or displace) particle position with an animated texture map ? similar to Scale operator (works fine).
when I try Position Displace (timing continuous) it will add up the changes.
I am new here. thanks for the help ?
property test operator can be used to save texture intensity to custom property,  I don't if it is the only way but it works.
.max   textureIntensity.max (Size: 672 KB / Downloads: 365)
amazing thank you !!
