Force field driver
XP有力场驱动,不错,ty也可以加一个
XP has a force field drive, which is good, and ty can also add one
“surface force”操作符了解一下。
Learn about the "surface force" operator.
In tyflow, the force field exists in many and different ways. For example, force, particle force, point force, flock, path follow, VDB force and other operators, combined with several force vortex fields, can meet most projects and requirements. If you really need a finer and higher definition, you need to use the "script" operator.
(07-29-2021, 06:12 AM)视频 Wrote: “表面力”操作符了解一下。
了解“表面力”操作符。
在 tyflow 中,力场以多种不同的方式存在。例如力、粒子力、点力、群、路径跟随、VDB力等算子,结合多个力涡场,可以满足大部分项目和需求。如果确实需要更精细更高的定义,则需要使用“脚本”运算符。
好的谢谢你。我会了解更多
