Pressure washer flow
I am having trouble setting up a pressure washer flow. I have used surface force to get the fanned out spray pattern look, but then I link the surface I am emitting the particles from to a moving object the spray goes haywire.
Any suggestions?
Thank you.
How the spray reacts to your moving object all depends on your Surface Force settings and the movement of the object...you'll have to post more info about that and/or the scene file.
