TyCache: continue cache re-calculation
You can observe the issue in the video I posted on fb group:
https://www.facebook.com/salvo.triolo.9/...646917599/
Is an old working file but today it doesn't.
The trouble seems to be the "spline paths" operator...disabling it all works fine but this isn't a solution.
In the thread that I started in the tF group a user encountered same issue using other operators.
Tyson, can you analize the problem and explain how to solve?
Edit: the problem is not the spline operator it self but the "include spline path geo" option actived in the export operator.
You haven't posted any info about the setup. Can you attach the file?
(08-27-2019, 04:30 PM)tyFlow Wrote: You haven't posted any info about the setup. Can you attach the file?
Here it is
.rar   Ty_spaghetti_&_polpette_PhysX_07_test.rar (Size: 735.12 KB / Downloads: 355)
I'm thinking...could be that problem caused from win10 update I did a week ago?
I noticed that, after this update, max not closes properly and remains in background mode.
Googling in that direction some guys complain this.
I see the issue now and will fix it in the next build.
In the meantime, a workaround is just to enable sim caching in your flow. Currently it's disabled.
(08-28-2019, 03:52 PM)tyFlow Wrote: I see the issue now and will fix it in the next build.
many thanks, good work.
