09-08-2019, 10:04 AM (This post was last modified: 09-08-2019, 10:04 AM by d4rk3lf.)
Well, that option in PFlow, imho is pretty useless.
You define particle count anyway in the birth event, why would you want to limit the amount as a second input?
As far as I know, Tyflow have no such a (useless), and basically maximum particle amount is defined by physical Ram memory.
(09-08-2019, 10:04 AM)d4rk3lf Wrote: Well, that option in PFlow, imho is pretty useless.
Just use birth.
After birth, we can produce more and more using different methods (spawn, branch). Also using Birth By Volume, you can incorrectly set the settings to cause the crash scene. Using Pflow I always use Upper Limit.
