I'm on v.16045.
This is stated in the release notes of v.16044:
"fixed an issue where applying a Meshsmooth/Turbosmooth to a tyFlow or tyCache would take an extremely long time to calculate"
However, applying Turbosmooth to a TyCache is still a problem - takes as much as 20-30 seconds per frame, while the same sim as a TyFLow (before export) takes only a second or two to turbosmooth.
This is with about 300 mesh elements (probably about 20K triangles total), which is the first stage of my sim.
In stage 2, when it gets to several thousand chunks, Max simply hangs upon aplying TS to the TyCache and never wakes up. Does not crash though .
