09-21-2019, 06:45 PM
Hello i have some problem with Vray motion blur (maybe its not just vray) im using quite simple flow where i need to delete some older particle (but i did test without deleting them and its same) If i export to alembic there is no motion vectors so its not the way for me.
So here is single image with motion blur that works (it happend if i render just one image from timeline 1-500) it also works when i render animation then first frame from sequence works fine.
![[Image: Fr5Xpq4.jpg]](https://i.imgur.com/Fr5Xpq4.jpg)
here's example for the other images from sequence if i render animation (motion blur looks weird)
![[Image: hVeXoTg.jpg]](https://i.imgur.com/hVeXoTg.jpg)
in the attachment is also MAX2019 scene for debugging (there is GPU vray settings now but i did test CPU too and it didnt work also)
Thank you for any help!
tyflow_motionblurproblem.max (Size: 1.55 MB / Downloads: 537)
