tyFlow v0.16048 (BETA)
tyFlow v0.16048 is out!
http://beta.tyflow.com
* added tySelect modifier as a feature-rich, robust replacement for max's Vol. Select modifier
* Limiter operator now has position variation setting
* Display Data operator can display event index
* Link to Target operator now has settings to disable linking of pos/rot/scale
* tyFaceExtrude "exponent" parameters replaced with curve controls for defining custom soft-selection curves
* Speed operation now has interpolation parameters as well as the ability to choose between setting/adding to existing velocity values
* "Has Shape mesh" test added to filter rollout and Property Test operator
* Shape operator now has timing/filter rollouts
* tyParticleSkin can now filter input particles by groups
* Object Bind "verlet integration" setting allows particle velocities to match their relative motion of the surface they're attached to, regardless of surface stickiness
* added option in Face Extrude modifier to select affected faces
* added options in Property Test neighbor search to use neighbor radius or combined radius in proximity test
* added event index property to Custom Properties operator
* added the word "noseed" into an operator's name will prevent it from being re-seeded during a PRT partition export operation
* added "grayscale force multiplier" option to Surface Force texture parameters for dampening accumulated Surface Force velocities with a texmap
* fixed a bug where the tyFaceExtrude modifier scale setting was not properly interpolating soft selections
* fixed an issue where selecting a tyCollection could cause its dependent flows to reset
* fixed an issue that could cause tyFaceExtrude and tyEdgeWeight modifiers to crash in some circumstances when operating on editable poly meshes
* fixed an issue where Export Particles could not create UNC paths
* fixed a bug where tyCache's GetParticleTMByIndex function was not returning properly interpolated TMs
* fixed a bug where tyFaceExtrude was ignoring vertex selections if soft selection disabled
* fixed a bug where tyCache objects would not adopt VRay global mtl overrides
* increased default value of Voronoi operator "max fractures per frame"
* fixed a bug where the Split operator could crash if its test action was set to increment custom float
* fixed a crash that could occur in the Path Follow operator if input splines have no internal shape
* fixed an issue with editable poly inputs to tyFlow functions not properly reading hidden edge flags
* fixed a bug where dragging an Export Particles operator to the top of an event would cause the event to disappear
* fixed a crash that could occur if you chose to include spline paths geo in the Export Particles operator, and also deleted the actual spline paths object in the scene
We're still waiting for the item Smile
* added support octane instances
(10-03-2019, 12:35 PM)Sidches Wrote: We're still waiting for the item Smile
and redshift =)))
