Add Selected
I'm wondering what to do with the "Add Selected"-Button in the TyHelpers Parameters.
Does it makes sense or do I have an error in reasoning?
Cheers,
Dirk
You need to lock the modify panel (little lock icon) first, then you can select your objects and press "add selected" in the tyHelper.
(10-17-2019, 02:42 PM)tyFlow Wrote: You need to lock the modify panel (little lock icon) first, then you can select your objects and press "add selected" in the tyHelper.
Ah, ok thanks!
