10-17-2019, 12:43 PM
Hey,
It would be really handy to get a flag on the prt exporter to skip existing cache files. (krakatoa has this) If you are caching a sequence and it crashes half way through you either have to manually set the frames to finish the incomplete sequence or overwrite the existing ones. It is a bit of a hassle manually setting the remaining frames because then you have to wait for it to finish that sequence before you can reset the frames to your entire sequence and continue with the rest of the partitions. A simple tick box in the general settings in the export operator would simplify this whole process as you wouldnt have to go back and fix up your broken partitions.
Thanks!
Thanks!
