multithreaded scripting approach
Hey there
How to script with multithreaded approach. I mean what to define in StartInx, EndInx and ThreadInx
I have already created the effect with script op, but now i want to multithread it.
Can you guide me a little....
What I have done is i have move particle parallel to the object surface in one axis by cross product objnormal and custom point3
but it very slow...
how shall i do the same thing with multithread on
Thank you
Nayan Bodawala
Call tf.SetThreaded as instructed in the Script operator comments, and then just change your for loop to use startInx/endInx instead of iterating over the whole particle array.
So instead of:
Code:
for (int i = 0; i < eventParticleCount; i++)
you'd use:
Code:
for (int i = startInx; i < endInx; i++)
The threadInx variable is just there for convenience, if you need to track which thread is being used for a particular chunk of particles being evaluated.
(11-06-2019, 10:55 AM)tyFlow Wrote: Call tf.SetThreaded as instructed in the Script operator comments, and then just change your for loop to use startInx/endInx instead of iterating over the whole particle array.
So instead of:
Code:
you'd use:
Code:
THANK YOU VERY MUCH
And we basically cut all our code from simulationStep into simulationStepThreaded right? So if you want all of simulationStep() to be multi-threaded then that function should be blank if implementing multi-threaded?
Also we don't call simulationStepThreaded(0, 6, 32); within the simulationStep() right?
That’s correct, yes.
