02-29-2020, 08:29 PM
(This post was last modified: 02-29-2020, 08:31 PM by Thermal_Graphics.)
So I just clean installed Max 2018 yesterday and "tyFlow_016071" today and dropped the 2018 version in the correct spot.
However, the trouble I'm running into is when I open the Tyflow editor, the panel on the right side of the window is cutoff halfway. No matter if I make the window full scren, resize it, try to make the panel bigger, it just doesn't work.
I also have a similar issue in Max where when I make cube, the parameters in the modify panel are also cutoff.
This is after a clean install less than 24 hours ago.
I have attached 2 screenshots, one of Max and one of Tyflow.
Any help is appreciated.
Thanks in advance.
I didn't see the attachments in my first post so I added them here again to make sure.
Thanks in advance.
