03-28-2020, 10:14 AM
tyFlow v0.16079 is up!
http://beta.tyflow.com
* Display operators added to a flow that contains particle shapes will default to geometry display mode
* fixed an issue where on some machines, quickType options would all appear to be selected
* fixed an issue where 3ds max 2021 would crash when you enter the tyFlow modifier panel, if you have the latest VRay 4.x for max 2021 installed
* fixed an issue where tyPreview mp4 files could not be played back in rv.exe
* fixed an issue where tyMesher would create empty meshes during local sequence rendering
* stub OpenCL.DLL files in Max root directory should not longer prevent proper OpenCL installations from loading
