04-01-2020, 09:22 AM
Someone has an idea of how it would be posible to create such an effect with tyFlow (Video Link at the bottom)?
I allready achieved the lines and the knots, but for the faces I don't have a solution yet.
Lines = tySplines (Neigbour or Bindings Mode)
Knots = Particle Shape set to Spheres
Faces = ?
tyMesher does't have such an option to build simple tri faces between particles as vertices.
I tried Extrude Modifier on tySpline with welded knots and bindings - thats not the desired effect.
Then I tried a combination of Surface Modifier and tySmooth Modifier (to break the smooth surface from the surface modifer) on tySpline object with welded knots and bindings - thats better but slow and even not really the desired effect.
Thanks in advance!
Faces = ?
Thanks in advance!
