04-08-2020, 09:16 PM
Hi!
I think It would be very useful when there could be a mode for the birth operators which birth particles just at "current time" (the frame on which the timeslider actually is).
For example I expierenced that its very slow to birth a volume of particles using "birth voxels" (high amount) and then use "object bind" to follow the objects animation.
The trick is that tyFlow doesn't calculate anything before the frame at which the first partilce is born. And for the case I wrote those calculations are not needed, so there could be a huge performance boost when just creating a new set of particles for each frame instead of processing an huge number of particles over a long time when its not neccessary.
Hope you understand my intension .
Thanks in advance!
Thanks in advance!
