05-04-2020, 03:28 PM
(This post was last modified: 05-04-2020, 04:13 PM by rjanders0003.)
Hello Mate
I been working on a visual help file with screen grabs and such - I am up to the "Set Target Operators" - I am on a slow connection and the visual type, so a pdf with screen grabs works better for me. Hope this doesn't offend you, as I planned to share it here for others who may find it helpful.
Great Job on this plugin - you are unbelievably talented - thanks for what you are doing
I noticed Documentation calls it "filters Rollout" but in Max the Rollout title is called "Target Filters" rollout
also:
In the manual on same page it says "neighbors" Rollout but in Max it is called "Proximity" Rollout
EDIT :
Also just noticed - "Instance Material" Operator appears as a choice in the operators selection panel in the editor interface - but listed in the manual as "material" operator
EDIT 2: I believe the "camera" rollout is not covered in the documentation for the "Mapping" Operator
regards
Rob
also:
EDIT :
regards
Rob
