More than one Editor UI opened at the same time
I noticed that it's possible to have multiple Editors opened at the same time.
Using the Node ON/OFF or deleting nodes in one will turn on/off or delete the node in the viewport and in the current Editor, but not in the second Editor.
Is it by design? Is intended to have multiple Editors opened? Or is it just missing synchronization?
Thanks!
Giuseppe
I'd say that's intentional. Each flow is self contained, it's not like Pflow.
I guess so, but it seems you can mess up flows making changes in different Editors
I don't see how you could mess flows up....each flow is self contained. If you make changes in the editor of flow001, it has no impact on the editor of flow002.
