concave shape
Sad
I had some difficulty simulating the chain
Is there a way to solve the concave shape problem, like in MassFX, you can set the concave. Is there any suitable solution in TYFLOW? thank you
I cooked up something last night before bed, but it's not the fastest.  I was going to try and see if using tyActors would work and speed things up.  Here is what I came up with.
.mp4   tyFlow_chains_002.mp4 (Size: 834.05 KB / Downloads: 380)
.zip   tyFlow_chains_001.zip (Size: 97.4 KB / Downloads: 344)
(04-06-2019, 12:06 PM)MeHoo Wrote: I cooked up something last night before bed, but it's not the fastest.  I was going to try and see if using tyActors would work and speed things up.  Here is what I came up with.
Thanks for your help. Now I'll try tyActors again
I've found my problem. Because I directly using the Voronoi Fracture operator cut objects, but after cutting objects convex hull is wrong, so the mistakes.
