07-22-2020, 07:21 PM
(This post was last modified: 07-22-2020, 07:45 PM by TheVFXBeast.)
3ds Max crashes when I run the tyflow simulation or create preview animation. I tried 4 times still having the same problem.
When I run it, it stops around frame 148, or sometimes 152.
So, I turned on the debugging to file, to see what is the problem.
The last thing that tyflow.txt written is:
start: Force
start: PreStepSimulation
end: PreStepSimulation
start: MTf: &forceBuiltinParticles
start: builtinForces
end: builtinForces
end: MTf: &forceBuiltinParticles
end: Force
start: Display
start: BuildMesh
The file of tyflow.txt is around 1.7gb.
Also sometimes when I run the tyflow simulation or create preview animation, at frame 148-152 3ds Max crashes, then a window pops up afterwards where it says The error report contents has three things... : 3dsmax_minidump.dmp dmpuserinfo.xml dumpdata.zip
Please help me fix this thing.
I am using 3ds Max 2021, tyflow2020.
start: Force
end: builtinForces
end: Force
start: Display
start: BuildMesh
