Hi Guys,
I have a problem rendering a sequence of 380 Frames. I exported all the 380 frames to tyCache files, wich works fine.
But there is only one frame (112) wich renders a totally diferent content in the sequence. It is always frame number 112.
I have deleted the tycache files several times and exported them again. The animation is rendered via Network rendering.
I have rendered Frame 112 also in single mode by different slaves but it has allways wrong content.
Rendered in tyPreview and in camera view in 3ds max everything is fine.
Any suggestions?
Thanks a lot
P.S.:
Maybe the flow helps, please see attached image
I also mentioned that the local host renders slightly different images, than the render farm.
Any suggestions?
Thanks a lot
P.S.:
