XYZ Multiplier Input for Noise Spread
Would it be possible to get separate XYZ multiplier values for the Noise Spread function in the Spread operator?  Thanks!
I think eventually most in-operator noise values (seen in Spread, Object Test, Surface Test, etc) operators will be getting improved functionality. Not sure when, but it'll happen eventually.
In the meantime, it's easy to reproduce the functionality of the Spread operator in a Script operator if you need more precise control.
