10-22-2020, 06:29 AM
Hey
I'm having a weird instant crash problem.
After adding the tyFlow.dlo into the 3DS max folder plugins folder.... and then trying to make a basic object 3DS instantly terminates.
Removing the tyFlow.dlo fixes the problem.
No error report is generated.
This happens in both 2019 and 2021 versions.
I can confirm a fresh install of 2020 with no extra scripts/ plugins works fine.
I read elsewhere on the forums that a particular script in startup causes a clash like this.
I don't have that particular script installed, but do have quite a few other ones and plugins ..... It's daunting to go and test which one is the problem!
So this must be caused by a clash with something. Q_Q. I can use the barebones 3DS for basic tyFlow stuff but obviously this a bit of a workflow blocker!
Is there a known cause of this? Or some things I can look at to fix this?
Cheers,
J
Cheers,
J
