11-25-2020, 12:08 PM
Hello, I wanted to figure out how the physics works in tyflow, for instance, in the real world the Force, which makes something move comes from mass x acceleration and when an object heats something the momentum which is in real-world equal mass x velocity transfer the Force to a kinematic object.
I want to know how this calculates in tyflow.
Based on my tests in physics shape operator the mass doesn't change the movement of a particle, for this test I prepared an event which shoots a ball with a force operator and the force push the Ball for 4 frames and then the force will be zero,(The wind Helper makes this 0 to 4 frame power) after that I add a physic shape operator but when I change the mass in Dynamics rollout the movement doesn't change, even when I add a mass operator it doesn't change by doesn't work I mean the motion line of the ball doesn't change.
What's the problem even I test these things without the physics shape operator and instead I used gravity force and that external force(wind)for start the movement, even with these settings the mass doesn't do anything.
What's the problem?
I have another question, I want to know how should I calculate the braking Force in physics bind operator or particle bind operator?(Without random numbers)
Is there any acceptable mathematical way to calculate it?
I hope someone answers my question.
Best regards.
What's the problem?
Best regards.
