Morphing from Sphere to Cube
Hello Tyson, pleasey help.
I have checked ALL tutorials on internet but did find answer on my question.
The question is how to make morphing from sphere to cube (just like an example)
https://www.facebook.com/100016515316444...4252420411
https://www.youtube.com/watch?v=9gu6CRDS...e=emb_logo
I want to make absolutely same BUT - in the end another object. How can i do that?
I was tried to find target another object - but its show just a silhouette of another object. But not 100% of the object. I could be for example 90%.
I was tried to make it with Custom Properties - but another object - wasnt work at all.
This is my goal (im just study) to make for example morphing from sphere to the box.
You can't. ..
...easily...
At least I think, you can't... someone can prove me wrong...
I mean, you can't if you want to use the fragments, and wan't to fragments perfectly align to new shape.
You can do it from, box to sphere, simply because you can make sphere from box by adding spherify modifier to box.
I did it here:
https://www.youtube.com/watch?v=sSWoUTqlf0g
So, you can do animation like this, only if both models have the same amount of poly's.
Then you can use morpher to transform chunks during travel.
Maybe in ZBrush is easy to make 2 models with same amount of polys's, but I am not using it, so I am not sure.
If you want smaller particles (like sand) to transform from A to B object... that you can do... and it's rather easy.
Wow finally - the answer.
Thank you, you know i was thinking about that, but i was thinking that im new one and maybe there is some way.
As i see we can do any dispresion of any object and then we need to create another operator to reveal another object and make it smooth (invisible transformation)
Only if both models have the same amount of poly's - this is very important information for me. Thank you!
Could you sure your file project scene from youtube?
Sure   Shy
.rar   Box_to_sphere.rar (Size: 924.13 KB / Downloads: 433)
Thank you!
