I'm trying to separate inner faces after fracturing.
1.
When I select by material ID with property test, it takes all chunks not only the faces of that ID. Is that right?
2.
I had also seen, I can check "Selection > Select cap faces", but I don't now how to select them.
How?
3.
my main task is to find out how export different material IDs with alembic to Maya.
But material IDs were gone lost.
So the only way I can see currently, to export mesh parts.
Is there another way?
4.
BUG with Alembic export:
Then there is a bug, that I have to reimport the exported alembic into 3dsMax and again to export from Max as alembic
Otherwise Maya immediately fatally crashes (2020.3)
Thanks!
1.
2.
How?
3.
4.
Thanks!
