04-07-2019, 02:48 PM
tyFlow wan't compatible with V-Ray Next when I made this test scene(https://youtu.be/qQ6jT0obme0). I might be 2 or 3 days ago? After that, tyFlow is compatible with V-Ray Next( wow! Isn't it too fast update? Thank you and Thank you!!!
), so I made a new test scene(https://youtu.be/oyuJA74W5NY).
BTW, I have one question. Actually the sequences for the test scene are around 265 frames. Unfortunately 3ds Max crashed at 99 frame. That's why the length of video is too short.
Is there any way to start the simulation from 98 frame, not from 0 frame? I have caches for the 98 frames. But tyFlow started the simulation from 0 frame even if I set the frame range from 99 to 265 of Export Particles. Do I need to start from 0 even if I have the caches for 98 frames?
Many Thanks!!!
Many Thanks!!!
