Hi~
Why can't animate the timescale in the "Main Settings Rollout"?
Maybe this is the same as attenuating or amplifying particle velocity?
Or
does it work the same as the simulation timestep?
if it's 2nd case.. then..
When an animation source created by an animator is converted from low to high speed or vice versa by the intended scene direction.
Wouldn't it be convenient if the timescale parameter could be animated and changed at particle simulation runtime? ~
i think. It will makes easy to match the animation source and particle simulation speed.
Thank you.~
Or
Thank you.~
