Partical Interface, expose events
Hi
It seems tyFlow does not expose Events properly. Here it is vrayInstancer's list of events it can see- it is empty. Although there are two events in tyFlow.
[Image: aFmvEXz.png]
tyFlow's events don't work the same way PFlow's do, and won't show up in event picker dialogs.
Is there an sdk documentation how to access them?
There's currently no way to access tyFlow's events.
If you need only certain events to be exposed to the particle interface, you can define them using the export groups buttons in the Interfaces rollout, and then define your export groups within the flow using a Particle Groups operator.
Sweet! That worked beautifully.
Great tip!
