Hi all,
is it possible that when using tySpline+tySpline mesher the vrayNext 4 makes the rendernodes crash?
I followed the neon spline tutorial by Jessy Pitela RedefineFX, and everything is ok.
When rendering with DR the rendernodes crash and close 3Ds max on the rendernodes.
Then I tried to convert the tySplines in editable meshes and then immediately the rendernodes are back working correctly.
TyFlow is 0.16098, 3ds max is 2020.3, on all machines.
The same happens with backburner, 3ds max crashes if tyflow+tysplane is active on network via Backburner (each machine renders a frame)
