obj position
I have an object rotating in the air, okay. now i realized that the animation shouldn't be at 30fps but at 60fps. but the object is not in the same place. how can I take an animation without changing the final appearance of the objects
I think the easiest workaround for a change like this to ensure the overall results don't change is to just enable the retimer on the tyFlow and set the playback speed to 50%, after you set the FPS to 60.
(01-14-2021, 03:55 AM)tyFlow Wrote: I think the easiest workaround for a change like this to ensure the overall results don't change is to just enable the retimer on the tyFlow and set the playback speed to 50%, after you set the FPS to 60.
thank you
