spline to keyframe tyspline export particles animated spline
Could anyone please give me some help explaining the workflow (Clearly---step by step)
For getting  an animated spline out of  tyflow and into max as as an animated geometry or even better still as an animated spline that you can still edit in splines. (so the object and it's data appears in keyframes.)... (Like string or rope etc)
Any help...greatly appreciated.
Thanks.
You can export splines to caches (both geometry and spline caches) using the Export Particles operator. Make sure you include your desired spline geometry in the Geometry rollout.
Thanks very much for your response
