VRay 5.1 and tyflow keep crashing
Hi, dont know why but when I render with latest vray and tyflow, 3ds max keep crashing...
This is what I got.
Really dont know where is a problem.
.dmp   3dsmax_minidump.dmp (Size: 8.43 MB / Downloads: 324)
Are you running out of RAM? That seems to be what the minidump is implying.
Can you try to trigger the crash again, but keep your task manager open while doing so? Then watch your system RAM to see if it's filling up.
No, memory is fine, around 12 GB from 64 GB.
Hmm, strange.
Since it's initially generating a VRay error, it's possible something else is corrupting memory, hence the minidump showing a memory issue.
I'd suggest passing the file off to ChaosGroup so they can further debug. I have no way of determining why their error message is generated and it seems like whatever is causing that initial error is cascading into the crash later, so the minidump isn't especially helpful here.
Yeah, I sent scene and everything already to Chaos.
But it is really strange, never had crashes like those in max and vray, only now when I used tyflow in scene. But absolutely dont know why. Should I reinstall something? Really dont know what is going on.
That's something the CS devs will have to answer.
