Angle change?
Hi, everyone.
The first event particle angle is vertical. To the second event, I need particles to do something else. However, once the trajectory of particles is changed, the angle of particles will instantly dump 90 degrees from the vertical angle, which is too strange. Is there any way to make this angle change and transition?
thanks
The z-axis of your particles will align to the travel direction when using that mode. You can either lower the interpolation value in your Rotation operator to smoothly transition between them, or adjust the offset spinners at the top of the operator to change which axis will orient to the direction.
OK, thank you for the tip. Thank you very much. I'll try it right away
