i can´t start a second max instance while i run a tyfolw simulation.
You'll have to be more specific about what the problem is.
I am running a cloth sim, which needs 10 min. While tyflow is doing the job, i want to work on other stuff. If i have a second Max opened before the sim started its no problem. But if i try to open a new Max while Tyflow is running the new opened Max crashes.
OK, i did test it with the last max versions. Its just the new 2022 version. There is no problem with the older. My 2022 max it totally fresh installed no plugins, no tyflow.
For the tyflow sim i am using max 2019.
