04-05-2021, 03:06 PM
Don't know if I am getting something wrong with tyflow setup and object export for a tyactor crowd simulation.
The object export option does not export the actor instance meshes. I am at loss as to what I may have set up wrongly. I added the mesh operator and set it to trimesh and unchecked render only. The simulation is fine, yet after a successful mesh export completion, I see only small boxes in place of the actor instances. Please anyone has an I idea what could be wrong here, that is assuming that tyactor sims can be exported to scene objects using the object export option. Help much appreciated.
cheers.
cheers.
