TyPreview_videos_file
HI,tyson!
I have a problem, I especially like to use it“
Typreview "to save the animation of the view. I've had a problem recently. About“
The default output path of "typreview" is in the "scene file" directory. By default, the generated video and max file are all together. When I constantly modify the file and record animation, dozens of videos are generated. So I need to clean up regularly, which can easily lead to misoperation and delete Max files. So I want to ask Tyson“
Can the default path of "typreview" be set to automatically create a "child folder" under the "scene file directory"? This subfolder is dedicated to videos
Yes you can modify the default save path using the supplied menu options (click the [...] button next to the path).
Then you can assign your desired path, which can include child folders which will be created. Ex:
$scenePath\Renders\example.mp4
You can also use relative path symbols ("..") to go up a folder level. Ex:
$scenePath\..\Renders\example.mp4
That's great. Thank you very much!
